Carbide Docs
Accessories
Shapeoko 5 Pro Dovetail Mount
Using the dovetail mount
  • Loosen the thumbscrew counterclockwise.
  • Slide the accessory into the dovetail so it sits flush with the top of the spindle mount. Each accessory has a locating pin
  • ​Tighten the thumb screw by hand clockwise to secure the accessory.
Compatible Accessories
  • DTI mount
    • A steel plate allows for a magnetic DTI gauge block to be fitted
  • DIY mount
    • An aluminum plate with a range of mounting holes to attach various accessories.
